SHEZ84 0 Posted November 15, 2006 Just wondered if any1 has had a problem in the past and resolved it. Have had it in 2 garages near york now and they can't figure it out. HELP!!!!! Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted November 15, 2006 an air leak anywhere after the metering head flappy paddle thing would cause over fuelling. Have you checked all the tubes? Quote Share this post Link to post Share on other sites
SHEZ84 0 Posted November 15, 2006 Air tubes seem to be fine. Cheers though! Quote Share this post Link to post Share on other sites
nocrap 0 Posted November 15, 2006 flappy paddle thing You talking about the metal plate inside the airbox? Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted November 15, 2006 flappy paddle thing/quote] You talking about the metal plate inside the airbox? indeed.. Quote Share this post Link to post Share on other sites
dubburke 0 Posted November 16, 2006 Alot of overfuelling problems seem to be linked with the lambda sensor. Quote Share this post Link to post Share on other sites
SHEZ84 0 Posted November 16, 2006 Might have a look at that then. Cheers Quote Share this post Link to post Share on other sites
SHEZ84 0 Posted November 17, 2006 Replaced the lambda and still the same1 Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted November 17, 2006 Is that 14 mpg according to MFA or is that calculated mileage per tank of fuel? Quote Share this post Link to post Share on other sites
SHEZ84 0 Posted November 18, 2006 Thats what it seems to average on the MFA. it does seem to reflect though in the amount of money i'm putting in it!! Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted November 18, 2006 Just check all the vacuum hoses are connected properly, this will give a low MFA figure if one has worked free Quote Share this post Link to post Share on other sites
SHEZ84 0 Posted November 18, 2006 cheers i'll check again. one thing i have had since i've had the vehicle is that the fuel pump seems pretty loud, a few mates have said this should't make a difference though. Quote Share this post Link to post Share on other sites
nocrap 0 Posted November 18, 2006 Yeah mine is too, changing the fuel filter might sort that....cant imagine that it'll make any difference to the fueling either Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted November 18, 2006 What i would do is fill up car, run until nearly empty clocking the miles. Fill up again, note litres used, devide by 4.55 to give gallons used and then devide your mileage by the figure you have worked out Quote Share this post Link to post Share on other sites
