steve @ 0 Posted November 16, 2006 Right basically need to replace my front mount. I know VF and VT make these but they are ££££££ (but alot cheaper in the states). I ve been searching on tinternet and it seems the lower half of the mount in the weak part(liquid filled). Turn 2 used to make replacement up rated versions for these, but have since long gone. Without taking a standard mount apart does anyone now how the bottom half connects(looks to be about an inch thick disk shape with a centre hole for the bolt, i assume the bolt goes through the whole mount, upper and lower? Thinking of maybe having a lower section made up at work. Quote Share this post Link to post Share on other sites
