akey1983 0 Posted December 13, 2006 Driving along at break neck speeds car died towed home, and found that engine is over fueling by alot changed ecu and still no different please help!!!! thanks Adam Quote Share this post Link to post Share on other sites
VR6 0 Posted December 13, 2006 A more descriptive title and what car it is may help ;) 8) Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted December 13, 2006 Just check all the connectors are still connected. Eg Lambda sensor, O2 sensor, etc. Check for any loose wires that have corroded loose. Check you do not have a boost leak, check all the air pipes are OK. Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 13, 2006 vagcom ? does it start and die ? maf ? Quote Share this post Link to post Share on other sites
