a98pmalcolm
WHATS THIS??
hay people can any body tell me what this part is (circled red) so i can order a new one beacasue its all broken up and wires are damaged in side!
Thanks
its where the ABS speed sensor connects to the loom.
theres a connector on the top of the tower (see your pic) and one on the speed sensor on the wheel.
its where you'd test the resistance to see if the sensor had blown/broken.
there'll be one on each side ;)
when ordering, that isn't the speed sensor, so don't order one of those :lol:
if the cable is cracked, you might have a bigger job if its the loom side of the connector rather than the sensor side (which is just a cable that runs the length of the tower from top to bottom)
no problem fella, as Supercharged says, strange thing to break as it isn't under any pressure or anything, it just sorta sits there.
Good luck
Do those things just pull apart then?
I need to do some checking re the below fault code.
1 Fault Found:
00285 - ABS Wheel Speed Sensor: Front Right (G45)
35-00 - -
