penfoldvr6
BOCSH RED TOP INJECTORS ???
Hi,
I've got a bit of aproblem with my vr6. When starting from cold its great, starts first time all the time.
After the engine warms up I can park her up, turn the engine off.
As soon as I go to start her she wont. She just turns over.
I found a way to get round this by trying to start then kill the ignition and trying again and it works great no probs.
I'm thinking i've got an injector problem, as in i've got a leak or a bad seal or something......Thinking about buying some BOCSH RED TOP injectors to try and cure this....DOES ANYONE HAVE ANY IDEAS.
Thanks CARL :?
i had a similar problem to this, turned out to be the ignition switch. there are a few threads on the forum about it somewhere...its quiet a common problem
Performance VW had this exact problem with theirs, it was the ignition switch and barrel.
