fatdaz 0 Posted January 11, 2007 went to start my car this morning, left it in gear as always, put clutch in turned key and it jerked forward, managed to get it out of gear, ten realised hi had no clutch pedal at all, apart from a tiny bit at the bottom of the pedal! so i had a mess, pumped the clutch etc, nothing, so i started it in 2nd down the hill and drove away, mesing with the pedal for abit, then finally it was back to normal????? Now im not sure wat it is, because the pedal didnt seem to get better with me pumping it, it strangley felt like a cable was stuck!!!! lol any ideas what it cud be??????? my fluid level is ok, not losing any???? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 11, 2007 Most likely the Slave - they leak internally to start with so you don't see the leak... Quote Share this post Link to post Share on other sites
