1st rado for me
Oil warning light
HI Guys
Suddenly I have started to get my oil warning light flash up , it is not all the time but more when under heavy load.
I have checked oil level which seams to be fine.
I do have a leak in my radiator could this be affecting the oil pressure?
Any ideas where to start would be greatly recieved.
I did not really want to start rebuild on the engine just yet I was looking at replacing every componant of my suspension first.
Cheers
i had the same problem, and after replacing the 2 presure sensors, the problem was the oil bomb , i replaced it and it runs fine
so to be stupid what is the oil bomb?
They look a bit like this
As said above though. Seems to happen quite a bit, and more often than not it's the white pressure switch/sender thingy on top of the filter head. Don't rely on that, though... Could always be something more serious.
