eatthis 0 Posted January 12, 2007 i own a supercharged golf vr6 obd2 just got the lower temp thermostat fitted and its feckin great when cruising 60-80 mph the water sits at 80 and the oil stays at 78-80 my question is A what temps do the 3 stages come in and B can you get diffrent sensors to make the fans come in a bit earlier? the reason i ask is im goin the nurburgring in april and need all the cooling i can get as im running 12 psi with no intercooler lol Quote Share this post Link to post Share on other sites
StormchargedVR6 0 Posted January 13, 2007 Im using low temp thermostat,fanswitch, and an oil cooler. These are the three best things you can do for the coolant system. My temp gauge hardly moves,and oil nevers goes above 100. Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted January 13, 2007 I also have a switch and stat, but I think I need a new temp sender switch, as it rarely gets above 70 degrees ! I have also noticed lower oil temps too ! Quote Share this post Link to post Share on other sites
eatthis 0 Posted January 13, 2007 where do i get them? Quote Share this post Link to post Share on other sites
StormchargedVR6 0 Posted January 13, 2007 where do i get them? Got mine from Awesome. check there web site Quote Share this post Link to post Share on other sites
eatthis 0 Posted January 13, 2007 cheers will do Quote Share this post Link to post Share on other sites
