eatthis 0 Posted January 12, 2007 mine suddenly sounds like a classic supercharger now (before it just whistled a bit) its not a knackered p[ower steering pump kind of noise it sounds just like a buzzy noise exactly like id expect a supercharger to sound BUT its deffo never made that noise before any ideas? could the water pump bearings suddenly go noisy the belt is pretty tight Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 13, 2007 could be the tensioner if the bearing is still original - easy enough to slacken and check - you just need an M8x80 Quote Share this post Link to post Share on other sites
eatthis 0 Posted January 13, 2007 im not using the tensioner Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 13, 2007 Oh sorry - didn't read it properly... Could be belt tension, make, or as you say waterpump or alt - maybe best to take it off and check the bearings etc, worth swapping belts reguarly on charged VR's anyways Quote Share this post Link to post Share on other sites
