oxfordpaul 0 Posted January 15, 2007 Hi, how long should it take to change the rear engine mount? What additional charge would be for the front one? Would you go for the vibratechnics on the front, OE or GSF? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 15, 2007 A garage should be able to do both in an hour - you need to loosen one to do the other anyways... On a VR6 deffo fit a VT mount, if the front breaks it's new bonnet time! Quote Share this post Link to post Share on other sites
oxfordpaul 0 Posted January 15, 2007 So if you were told 1 hr for the front and 1.5 hrs for the rear you would think that's too much? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 15, 2007 Yep... Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted January 15, 2007 you could do it yourself if you have a trolley jack, i did all 3 mounts on mine Quote Share this post Link to post Share on other sites
ziderapple 0 Posted January 16, 2007 I spoke to Stealth today about a front VT mount for my VR, lad on the phone said half an hours labour to fit it. (Although I'd do it myself) Quote Share this post Link to post Share on other sites
ZippyVR6 0 Posted January 16, 2007 But surely fitting a vibratronics front mount would put aditional stresses on the other mounts and speed up wear. Quote Share this post Link to post Share on other sites
steve @ 0 Posted January 16, 2007 Yeah took me half an hour to fit my VT front mount. The same again for the gearbox mount. Rear is a little more difficult so maybe hour (havent changed this one yet, but its next on the cards) Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted January 16, 2007 "But surely fitting a vibratronics front mount would put aditional stresses on the other mounts and speed up wear. " no ,the front takes most of the movement and surely a mount that doesnt move as much as a sloppy mount will make wear slow down ? the rear isnt too bad , i found the gearbox more awkward tbh , just get yourself three if poss socket extension bars then the rear is easy :-) Quote Share this post Link to post Share on other sites
Walesy 0 Posted January 16, 2007 I had my rear mount changed today at RKE and it took them about 15 mins. Quote Share this post Link to post Share on other sites
ziderapple 0 Posted January 16, 2007 Massive difference in job times between on your back on the driveway and in a garage on ramps though... note to self, must dig an inspection pit in my garage... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 16, 2007 note to self, must dig an inspection pit in my garage... Get a lift! Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted January 16, 2007 I had my rear mount changed today at RKE and it took them about 15 mins. not that much room at the back of a vr engine mate Quote Share this post Link to post Share on other sites
