Duecenickletreyg60 0 Posted January 16, 2007 i recently ordered a 3.5bar FPR and a Epron from BBM, i was wondering of these parts would be hard to install myself or if i should have them done and just pay the cost in labor. i have a decent amount of mechanical experience. any intructions or help would be appreciated, i have a 90 g60 if that helps!!! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 16, 2007 Did you get a pulley and belt as well? The chip is more a computer technician sort of job, need a PC tool kit with a chip extractor and some small torx bits but it's fairly straight forward with the ECU on the bench - chips are very sensitive to static electircity so make sure you ground yourself. FPR - fairly easy to swap, bit fiddly to get to but it's basically held on with 2 6or7 mm allen head bolts with one vac pipe and one fuel pipe going to it - gloves are a good idea! Quote Share this post Link to post Share on other sites
Duecenickletreyg60 0 Posted January 17, 2007 ya i already have a 68mm pulley and the serp. belt. where is the FPR located? as fare as the chip goes i think i will have it done! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 18, 2007 Hiya - FPR is located on the end of the plastic injector rail on the left hand side of the engine bay - the rail is behind the head and infront of the inlet manifold. When you get the new part you'll locate it easily enough! Quote Share this post Link to post Share on other sites
