JIMMI 0 Posted January 27, 2007 Im busy rebiuilding the interior on one of my corrados and i have a bit of a problem ! I completely removed the front seatbelt setup and the reels retracted into the reel. The problem is i now cannot pull them back out, no matter haw slpwly or what position i try to pull them they lock after a few mm's im pulling my hair out. I tried to dismantle one to see how it worked but that ended up in a wound up piece of spring steel firing at me. I know its not a fault with one particular reel as ive tried some spares i have and they are the same !!! Help!!!!!! Jimmi................. Quote Share this post Link to post Share on other sites
Slimg60 0 Posted January 27, 2007 I bolted the reel back into the car, and pulled really hard to remove and slack in the seatbelt, this then gave enough slack to pull the rest of the belt out. Quote Share this post Link to post Share on other sites
VR6 0 Posted January 27, 2007 Did this a few years back and, like Slim, I think I ended up bolting it back in the car in order to release it. Quote Share this post Link to post Share on other sites
dinkus 10 Posted January 27, 2007 You also have to have them the right way up - if they're upside-down, they lock. I guess it's on the assumption that the car has rolled and you really shouldn't have slack in the seatbelt :lol: Quote Share this post Link to post Share on other sites
andyVR6 0 Posted January 27, 2007 there set up to only release in the exact position that they are designed to be in. the locking mechanism will lock as soon as it is moved slighly my mate got his mixed up a few weeks back in his starlet and couldn't work out y. so they could be mixed up. Quote Share this post Link to post Share on other sites
