glen 0 Posted January 29, 2007 I ve found a good engine replacement of my tired 94 VR6 but it a dizzy engine, is it to much of a pain? should i look for another? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 29, 2007 Fairly easy..... You'll need to fit the following from your current engine:- ECU Rear cam sprocket and impulse sender Cam position sensor Chain cover plate Coilpack Leads Engine harness (from the twist lock section) Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 29, 2007 you should have all those bits already on your existing engine. Quote Share this post Link to post Share on other sites
