JoeNose 0 Posted January 30, 2007 I've recently had new OEM rear axle bushes fitted - and the car handling actually seems to have deteriorated somewhat. It's only noticable on the limit, during a rapid direction change. I am used not to having to slow down at roundabouts for example, just flick the car left-right-left with constant throttle. Good fun, and usually possible to feel the passive rear wheel steering working behind you. Now, the car seems sloppier than usual, with the rear end just not coping with the direction change as it used to. Other than checking geometry, what else is there for me to examine? I wouldn't have thought it possible to fit an axle bush incorrectly, so what else could have gone wrong? Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted January 30, 2007 rear bearings , you would be suprised how much a slack bearing can alter the car, making it feel twitchy but its unlikely as this has only happened since you had the bushes done , you could try playing with the coilovers to alter the damping now the bushes have stiffened the rear http://www.the-corrado.net/wiki/index.p ... xle_Bushes Quote Share this post Link to post Share on other sites
corozin 0 Posted January 31, 2007 I agree. The first thing I would check is that the rear bearings are nipped up just snug. If they aren't the car will feel like the front and rear wheels aren't connected to the same car. It's also a common oversight for garages to make. Hell I even had to tighten some rear bearings fitted at Dia.... no - I won't name them. Quote Share this post Link to post Share on other sites
JoeNose 0 Posted February 1, 2007 Thanks fellas, will check it out. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 1, 2007 I wouldn't have thought it possible to fit an axle bush incorrectly, so what else could have gone wrong? It's very easy to fit them incorrectly, both in terms of rotational angle and also how far they are pressed in. Quote Share this post Link to post Share on other sites
