radar 1
heavy handed fool!!!
Hi, i recently got hold of a 1.8,16v thats been sat in a yard for a year and guess what i did :oops: just been sortin the odd things and i have discoverd that two of the bolt holes in the n/s rear hub are stripped,( not me honest) any ideas how i can fix this?
Yes sorry rear disc, but once the disc is removed i thought the holes and stripped threads would still be on the car in the hub/stub axle bit ? or does all this come of with the disc? i was thinking can i re- tap the threads, and if so how do i go up a size in wheel bolt? becouse with only two bolts holding i cant safely move the bloody thing :mad:
Why do these things only happen when its cold wet and dark!!
No just change the disc mate - it's held on with a split pin (!!!) - taper style wheel bearing...
New Disc and Bearing will be about £30 but you may want to do both sides plus pads...
