Hans G60.nl
Headlights with a good beam
Hey guys, i think you all know the same problem i have... the headlights of a corrado aren't really what you can call a big-beam...
so i've made a schematic solution... now i only have to work it out, but i'm 200% sure that it works.
i'm afraid i have to translate something:
grootlicht - high beam
dimlicht - low/ normal beam
accu- battery
originele draadboom- original wiring
aansluiting - connection
massa - minus pole from the electric circuit..
may there be any questions, just let me know
what the "mega beam unit" does:
it creates 13.8 volt from your battery on your lights instead of the usual 11.5 volt that's going into your lights (rest is lost somewhere in the original circuit)
the second thing it does... usually when you pull the high beam lever, you get shortly a big beam which becomes less when you release the lever, that problem is solved now by using the high beam of the H4 light (low beam usually, but allso has a wire for high beam) and using the normal high beam on a higher voltage.. (again some volts are lost in the original circuit)
