Corradokid135 0 Posted February 14, 2007 So here's my problem. Recently i have been having this problem where my clutch pedal won't return all of the way back and it gets stuck to the point of where i have to put the toe of my shoe behind it to pull it back. Also another thing that has been happening is when i am at a complete stop with the clutch in in 1st gear she'll keep try to creep forward :brickwall: . So my question is what could be the problem of this? The clutch is a stage three clutch that was installed a little over a year ago and untill this last month i have had abosolutely no problems with it. Any info or suggestions you might have would be greatly appreciated , Thanks :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 14, 2007 Did they change the slave when they fitted the clutch??? You have a leak somewhere and it's most likely the slave or the flexi pipe leading to it - check the fluid level and for leaks ontop of the gearbox. Quote Share this post Link to post Share on other sites
Corradokid135 0 Posted February 14, 2007 I really don't know if they did or not because i bought the car a mont after the clutch was put in. But i will surely check that out asap to see if thats the case. thanks so much for your help. Quote Share this post Link to post Share on other sites
