latestarter2 0 Posted February 18, 2007 As the description really...its started in the last couple of days.The lamp goes out after starting but then came on whilst driving. The oil level is fine suggestions?? cheers Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted February 18, 2007 Check the oil pressure switch,replace it then if it still is the same,get the oil pressure tested ASAP or it could be a new engine for you. Quote Share this post Link to post Share on other sites
latestarter2 0 Posted February 18, 2007 like the others on here it was when i was moving on tick over..low revs Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted February 18, 2007 If the oil light came on at any time while it was running with me i would have it sorted asap without fail. Quote Share this post Link to post Share on other sites
latestarter2 0 Posted February 19, 2007 good for you Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted February 19, 2007 why did you post this then? Just for someone to tell you it will be fine and keep on running it? I mean all cars oil light should come on when idling right?,so its nothing to worry about. Good, glad its all cleared up. Quote Share this post Link to post Share on other sites
latestarter2 0 Posted February 20, 2007 oooohh!! lol! Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted February 20, 2007 Muppet.. Quote Share this post Link to post Share on other sites
