poll250
Fuel Cut Off Switch
Hi,
Does anyone know where the fuel cut off switch is located? We had a look at the garage trying to get my car started again and couldnt find it anywhere?
Cheers,
Andy
anyone! Ive searched all over but cant find out how to get it running again to get it home! arghhh
Ive found info about a deceleration fuel cut off valve, is that not something to do with it?
Basically straight after my crash the car wouldnt start at all ,and I was told it was probably because of a fuel cut off system or something?
Any other ideas why it wont start? it doesnt even turn over, just nothing!
The fuel pump relay requires a signal from the ECU (basically, an earth) in order to trigger.
Check the earth on the relay.
That is implemented as a crash-cut-off. The ECU drops its earth which would deactivate the fuel pump.
Cheers man, ill have a look for it when I get home tonight, the garage should be dropping it off later, just thought itd be better to having a running car for sale than a non-runner!
Thanks again,
Andy
