joebrent
tyre pressures
I put 30 psi in all round. You can put more in the rear if you have an exceptionaly heavy load, but to be honest there must be few people that can be bothered to alter there pressures dependent on load.
Most Corrados require slightly more than that, I thought, due to their weight - particularly at the front.
But it depends on the width of your tyres...
I can tell you that pressures too low kills the precision of the steering...
FYI a VR6 requires 36psi in the front wheels and 33psi in the rear...
take a look on the inside of the drivers side door, there should be a plate there with a list of pressures required for both front & rear loaded & unloaded. I think all German cars have 'em there.
Most bizarre... mine says 38 psi front and 33 psi rear... surely my engine's lighter :?:
(or is that because of different tyres 195/50/15)
DtM.
DtM.
Yep. Spot on.
