Balti Pie
koni/H&R Set up
Got a valver and am after the Koni dampers and H+R spring set up that seems to be favoured by many on here. Does anyone know the cheapest place to get them from?
hi Craig, no worries about my suspension :) but in your wanted thread chrisp has said he has some konis for sale, have you contacted him??
karl
Hi,
I would consider fitting the VR H&R springs and not the valver/G60 ones myself - I think the spring damper match is much better and there is not that much weight difference between the VRw and 16v/G60s.
I have tried both sets of springs and am running the VR ones now.
Thanks for the advice Yandards. Do you know where I can get them from. Also which Koni shocks should I be getting, there seems to be a few for a valver.
Rears should be about the same, I think you can only get koni sports (yellow) dampers for the C.
Make sure you get a complete strut tower for the front and not an insert tube thingy, they are rubbish and you will probably never get them fitted.
Dampers from here
I would go with 8741-1259 Sports for the front and 8041-1108 Sports for the rear. Both gas top adjustables with complete struts.
