dav 0 Posted March 12, 2007 Hello Just done a load of work on my VR amongst the things I changed was the rear engine mount. Plus points: I have greatly reduced engine movement Negative points: seem to have a lot more vibration now? I have a VT front mount fitted already but I remember there being some kind of trick like letting the engine idle for a while with out the mount nuts tightened up the let them settle in? True???? Thanks Dav Quote Share this post Link to post Share on other sites
steve @ 0 Posted March 12, 2007 Yeah if you fitted just a rear mount. undo the gear box and front mount then push pull the engine then re torque all mount nuts. Was it a standard rear mount you fitted? Quote Share this post Link to post Share on other sites
dav 0 Posted March 12, 2007 Thanks Steve yep the rear is standard and the gearbox mount is the tdi one (heavy duty?) it was a proper pain to change though i had to remove the bracket. do you knoe the torque setting? Thanks Dav. Quote Share this post Link to post Share on other sites
