B4LJX 0 Posted March 14, 2007 I have a g60 corrado, have been driving it fine for the last couple of days before that on and off weekends only and today would not start tried it a couple of times and it started, it doesn't sound as it normally does and the whole car is vibrating like mad especially the stearing wheel and the engine moving around more than normal on idle engine any thoughts?? thanks bal Quote Share this post Link to post Share on other sites
nocrap 0 Posted March 14, 2007 I would say that one of the cylinders isn't firing..... Quote Share this post Link to post Share on other sites
B4LJX 0 Posted March 14, 2007 would that have anything to do with the spark plug leads?? may not be connecting properly??? or a more serious issue? Quote Share this post Link to post Share on other sites
VR6 0 Posted March 14, 2007 Plugs and leads would be a good and cheapish place to start. Quote Share this post Link to post Share on other sites
leederg60 0 Posted March 14, 2007 Way to test is start engine, then one by one pull off the leads if itn gets worse put that one back on, if no difference you have found your missing cylinder! Take the plug out on that cylinder and check if full of carbon, if it is try new plugs and if still nothing borrow a HT lead test light! Sounds a lot but ten mins work really. hope helps Quote Share this post Link to post Share on other sites
