falconer01
Heater Valve
Heater on my 1991 1.8cc corrado not working , i have tested all sensors etc & car is running at normal temp. Leaving onlythe heater valve the hose is hot upto the valve, but i think its returning the water through the bypass outlet on valve. Is there a way of testing this valve also VW dealer says it was a comman fault & a recall item. Thanks
Hi
Ring a VW dealer with the car registration number and they will check if there is any outstanding recall work on your car. The heater matrix bypass valve was a recall.
The other way is to replace it yourself. About 30 quid.
