corraptor_evo 0 Posted March 22, 2007 Does anyone tell me, clearly, what BOOST must have a stock-new G-Lader at DIFFERENT rpms (at 2000, 3000, 4000, 5000 rpms)? I know the boost must be 0,8 bar (11,3 psi) checking at red line (6200 rpm). How i must to check it: standing in my yard or on street? What rpms, what gear, what boost? I check it yesterday: 1,1 bar (17 psi) with full throttle just(!) at 7000 rpm: BarTek RS kit (chip, 70mm pulley, ISV restrictor), self made RSR charger outlet (removed the G silencer). It is good, or is it bad? Plese, i need details? Thanks a lot! Quote Share this post Link to post Share on other sites
DanVW 0 Posted March 22, 2007 17psi is good for a stock G60 charger you might want to fit some bigger injectors (red tops) to make sure your flowing enough fuel you dont want it to run lean! But I would avoid running your engine up to 7000rpm!! As its not good for the charger, am sure someone will be along soon to let you know if there is a boost chart for the G60. Quote Share this post Link to post Share on other sites
corraptor_evo 0 Posted March 28, 2007 DanVW, thanks for your advice. It seems there is no one having a boost chart. Or this subject isn't enough interesting... Well... I still waiting... Quote Share this post Link to post Share on other sites
