Riley
Steering column upper bearing
Think mines knocking slightly...whats involved in replacing it? Done it on golfs before,same idea?
Neil. :)
No but you need to pull the splined adapter off with something and also drill out the lock barrel... also a good time to change the ignition switch for the uprated polo 6N one
Cheers m8,whats involved with the polo ignition switch swap? first time ive heard about it. :)
Been a while since doing one,couldn't think whether or not the barrel needed a hole drilling...Will probably get a new splined adapter too.
Neil.
Bump from the dead :D I'm having this exact same issue, can you gents please provide more info on the upper bearing replacement and this Polo 6N switch you speak off? I've been researching these two topics to death but couldn't find much on them.
