yalan
detached wire - what won't work?
Hi.
Can anyone identify what will be struggling as a result of this disconnected wire?
Seems to have freyed at a connector block which is mounted to the rear engine mount.
Can't follow the wire very easily to trace.
Cheers
hmm interesting.
probably best get it connected again before next MOT then.
Strange - would have expected some running issues.........
cheers!
Depends what wire it is - if the ECU thinks it's disconnected then it will revert to a fixed value or rely on another sensor...
Best way to fix is to get a yellow repair wire from VW which comes pre-terminated then solder / heatshrink to rest of loom... the difficult bit is getting the old wire out the plug!
Also check your engine mounts!
