seizure
02A Gearbox ratios
I have a CBA (G60) and an AMA (Passat GT) box lying around and I would like to know what ratios they have in em, but I am also keen to know the ratios for the other 'boxes.
Cheers
I can't answer your question, but I can welcome you to the forums :)
Welcome! :D
I'm in the UK, and don't have a Bentley manual. Already been on Vortex to get em from there, but they said the UK and US 'box specs differ.
Sorry should have mentioned this earlier; I need the UK 02A gearbox ratio specs.
Cheers
02A is the type of box the letters after it explain the ratios hence CBA AMA even uk G60 boxes are different from year to year from what i've read
G60Jet is right the gearbox ratio's do differ from year to year the gear ratio's for the ATA gearbox which runs from 5/89>7/90 are as follows
Ratios final drive 70:19 = 3.684
1st gear 34:9 = 3.778
2nd gear 40:19 = 2.105
3rd gear 39:29 = 1.345
4th gear 34:35 = 0.971
5th gear 35:44 = 0.795
reverse gear 19:9, 36:20 = 3.800
And the gear ratios for the AYL gearbox 8/90> are:
2nd gear 36:17 = 2.118
3rd gear 40:28 = 1.429
4th gear 35:34 = 1.029
5th gear 36:43 = 0.837
And they are the same box type the 02A
02A is the type of box the letters after it explain the ratios hence CBA AMA even uk G60 boxes are different from year to year from what I've read
Yeah I know - You're right. VW did "Tweak" the ratios, that's why I need a complete list of ALL 02A boxes. It would also be helpful for future reference should I decide to raid the scrap yard for another £25 'box.
There's not many boxes you get in this day and age for £25 :wink: [subtle undertones implied]
Cheers
This is the list of 02A gear ratios I have compiled for USA cars and I had posted it on the vortex for siezure. But please tell me about the CBA and AMA tranny codes I didn't follow where you went with that :oops:
_________1st___2nd___3rd___4th___5th___R&P___Notes
ATA====3.778 =2.105 =1.345=0.971=0.795=3.684==Corrado G60
AYL====3.778=2.118=1.429=1.029=0.837=3.684==Corrado G60
CAW====3.77=2.118=1.458=1.034=0.838=3.647==Corrado G60
CDM====3.300=1.944=1.308=1.034=0.838=3.647==Corrado VR6
AGC====3.778 =2.105=1.345=0.971=0.795=3.944= Passat 16V
AYK====3.778=2.118=1.429=1.029=0.837=3.684= Passat 16v
CES====3.778=2.118=1.429=1.029=0.837=3.684== Passat?
CHA====3.778=2.118=1.360=0.917=0.717=3.944==VR6 Canada
CGY====3.778=2.118=1.458=1.029=0.837=3.684== Passat?
CNL====3.778=2.118=1.458=1.029=0.837=3.684==VR6 Passat?
CCM====3.300=1.944=1.308=1.034=0.838=3.389==VR6 Passat, Jetta, Golf
CTN====3.778=2.118=1.360=1.029=0.755=3.157==Jetta/Golf TDI
DQY====3.778=2.118=1.360=1.029=0.755=3.389==Jetta/Golf TDI
ASD====3.300=1.944==1.308==1.09==0.717==3.16==TDI I've heard of a few being bought in the USA but I believe its a euro MK3 TDI tranny
CHN==== Golf
CHU==== Passat
CRU==== Passat
O2C trannys (SYNCRO):
CBC,CHD=3.778=2.118=1.360=0.967=0.769=3.938== Passat Syncro CDN
AYR ====3.778=2.118=1.345=0.971=0.756=3.944== Passat Syncro
CDH====3.778=2.118=1.360=0.967=0.769=3.938== Passat Syncro
Cheers G60ing. You to have done well.
Not sure what you meant about not following my post. I have two 02A cable change gearboxes. Their codes are: CBA and AMA. The CBA is out of a Corrado G60 and the AMA is from a Passat GT. What I am after is the ratios for those particular boxes, but I am also interested in the ratios for other 02A 'boxes so I can search out the ones with favourable ratios and use them in future "projects".
But bear in mind I'm in the UK, so I'm guessing the gearboxes will be different to those in the US, cos of our different driving environments and driver requirements.
Why bother, just get a good 02A box and get if rebuilt with the ratios you want and get a 6th gear dropped in too!!
