Cnut
Power steering sticking
When the car is first started in the day the steering sticks slightly when you turn, after a few hundred yards the symptons go and everything is normal.
I have changed the steering fluid to the recommended VW stuff but that hasn't made any difference.
What could be causing it?
Its on VR btw if that makes any difference cause I never got the same problems with my valver.
check the belt for cracks between the vvvvvvvv teeth . mine was knackered so i measured it then went to halfords then measured belts in stock untill i found the correct sise, dont bother with thire reference book as it was incorrect the belt that fitted my 1991 1.8 16v was hb750a 30"" drive belt , i fitted it this morning and now have power steering again
belt will be on off the shelf at halfords £ 3.20 or so an easy fix to do yourself you will need a
13mm ring spanner
13mm socket and wrench
wd40
{well thats what i needed for my 1991 1.8 16v}
once you have the new belt on, go for a short drive { not to far} just enough to warm up the belt .
the new belt will probably stretch a bit and power steering will start to whine
so then you tighten the adjusting bolt up to get tension back on the belt
13mm ring spanner
wd40
Thanks for your help
Stan 24v, thats for a VR6 serp belt tho... 16V's have a seperate PAS belt.
Dude see below :lol:
cnut stick with the advice i gave you mate . its worked on my 16v i did it last sunday, and my power steering has worked correctly all week
Yes but that was on a valver, and he has a VR :roll:
