G60-NeedMoorePoower
[golf MkIII ABF 2L 16v]VAG distributor part no lookup pls...
hi
motor :
1996 (??)
golf mkIII 2L 16v ABF
...I don't access to VAG...
can someone pls confirm if 037 905 205 M -is the right distributor ?
Are there some common distrbutors -perhaps another MkIII / Mk IV ?
Thanks
If your original dizzy is marked with the part number you listed then you need to order a 037 905 205 CX type and exchange your old dizzy at the same time.
...er....ok....is the CX the lastest "version" of this part then ..?
Yes, although if you go in and order the other part number that would be fine.
I doubt the seat part would be any cheaper, but you could always try.
thanks for info
