tallpaul1977 0 Posted April 7, 2007 Hi, i bought a Corrado with a 1.8t conversion, but have noticed that the cambelt pulley & cover is rubbing on the master cylinder. Is there another master cylinder(less depth) that i can use? Or is there any other way around this problem? The corrado was a 1.8 16v ('90) before the conversion and has no abs. Quote Share this post Link to post Share on other sites
MurphG60 0 Posted April 7, 2007 Think there is something that needs to be done to the front engine mount to make it clear not sure though??? Sure someone knows better... :) Quote Share this post Link to post Share on other sites
rado-steve 0 Posted April 7, 2007 Mine dunt catch :) Quote Share this post Link to post Share on other sites
biggerbigben 0 Posted April 7, 2007 you need to change the M/S to a mk3 16v abs 23mm job which has 2 outlets on the drivers side and none on the passengers side. Should then clear by at least 5mm. Ben Quote Share this post Link to post Share on other sites
tallpaul1977 0 Posted April 10, 2007 Thanks for the info Ben. Have seen a photo of the master cylinder on the coupehaus site, is it possible for you to send me a larger picture? Does your engine move much, have you uprated the engine mounts? Quote Share this post Link to post Share on other sites
Dr_Redz 0 Posted April 11, 2007 you could use a seat Ibiza cupra 23m cylinder its a stubby little thing that gives bags of room 17m last time I measured mine Quote Share this post Link to post Share on other sites
tallpaul1977 0 Posted April 12, 2007 thanks dr redz, what year Ibiza do I need to get the cylinder from? Also would you have a part number by any chance? Quote Share this post Link to post Share on other sites
tallpaul1977 0 Posted April 16, 2007 Does the Ibiza Cupra/Golf mk3 have 3 outlets on the brake cylinder? Currently I have 2 facing the drivers side and 1 at the back going towards the passenger side. Please help someone! Quote Share this post Link to post Share on other sites
