eatthis
poorly obd2 charged vr :(
mines suddenly running mega rich ie misfiring and black clouds out the back :(
if u drive it normally ie low revs/throttle it seems ok but if i give it some it starts running terribly doesnt want to idle rough as hell when pulling off really smokey
theres also a noise that gets worse its a bit like a fan it gets worse with higher rpm and u can hear it from about 3k onwards i can only hear it in the cabin i cant hear it in the engine bay
I can't see piston rings causing all the problems mate. The smoke maybe, but i don't think it sounds like ya rings.
How many miles on the engine mate?
Could be the plugs are oiling up rather than getting clogged with fuel. I don't think fuel can clog the plugs can it?
106k its been usin a fair bit of oil but not smokey
when it smokes its thick black smoke like a diesel not oil smoke
iv suspected the water pump is a bit iffy recently the noise has gone away now and the car drives fine if im sensible but if i give it the beans it starts running bad i suspect piston rings :(
a compression test would prove this either way wouldnt it??
wheres the best place for a rebuilt/new bottom end??
