jonny-5 0 Posted April 16, 2007 Could somebody show me where the oil lines go to and from on the block of a G60? Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted April 18, 2007 Well seeing as you've only got a supply and return it's quite simple,the G-charger's oil drain is fed back to the sump by using a short lenght of rubber pipe attached to a barb that's screwed into the engine block. The oil supply braided pipe is connected to a banjo bolt arrangement on the side of the cyl. head along with the black oil press. switch. Quote Share this post Link to post Share on other sites
