diggerbucket
My Aqua blue VR6
Well it's about time I got a couple of pics on here, just been out to take these tonight.......
Specs are:
VR6, standard
Koni coilovers
OZ futuras, 16x9 on the back, 16x8 on the front
Red rear lights
Milltek exhaust
That's it!
you forgot the red rears and the oval tailpipe!!
just goes to show how nice semi standard corrado`s can be
looks lovely!!!
I've only had them on a couple of days and I was fully expecting them to rub at that height but it's been ok so far. And that's as low as it can go without hitting the massive speed bumps on my street, so I may get away with leaving the arches alone.
The rears are 16x9, ET15
Fronts used to be the same but I changed the outers to turn them into 16x8s, and I had to use an 8mm spacer to clear the brakes. Can't be bothered working out what offset that is :lol:
The back did catch once today over a big bump, wouldn't like to go any lower without any arch work. The Konis are still on the softest setting which I'm pretty happy about :)
Well after a few more miles I've found the back to be rubbing over some of the bumpy roads round here. Stiffened up the Konis a bit to try and counteract it. Can't decide what to do with the arches now, guy at the bodyshop said he would cut them back a bit and reseal them but I'm not sure I want to do that!
