drunkenmunkey
Bugger! Crack pipe cracked - easy to DIY?
Brilliant it even has a fitment guide page :)
'twas easy enough as you say, I just unbolt the front mount, jacked up the engine, removed one thermostat pipe to let it be moved & undid the 3 bolts, pulled the 'crack pipe' from each end & it's out! Really wasn't expecting it to be that easy - new stainless one on order.
Thanks ziderapple :D
