GivemeaVR 0 Posted May 16, 2007 Are the leads the same on a distibutor setup and a coil pack setup the same? All i can see thats different is a slight difference in length. Would it be ok to use distributor set up leads on the coil pack setup? Thanks Quote Share this post Link to post Share on other sites
blackboy VR6 0 Posted May 16, 2007 i got some from dubpower for a coil pack and he told me they were all the same, the kit came with 7 leads, and they work spot on Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 16, 2007 One set is longer but can't remember which - look on vwspares... Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted May 17, 2007 The distributor set up has longer leads. They work with a coilpack but are not very tidy. best wishes RB Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 17, 2007 Except for the genuine VW parts - apparently the coil pack set have a better attachment at the plug end. Quote Share this post Link to post Share on other sites
GivemeaVR 0 Posted May 17, 2007 I put the leads on and they were fine. The only thing was that they were slightly longer but managed to tidy it up. The plug end connectors were ok but needed slightly more pressure to get them to 'click' on. Thanks for the help. Quote Share this post Link to post Share on other sites
