cvw 0 Posted May 20, 2007 after draining all the water and coolant from my car yesterday to replace the matrix the temp warning light wont stop flashing , does this mean i have air in ithe system somewhere and how do i get rid of it. Quote Share this post Link to post Share on other sites
nocrap 0 Posted May 20, 2007 The light will flash if the water level isn't high enough or its too hot.....in this case it seems as if there isn't enough water in the header or the sensors knackered! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 20, 2007 You may have also pulled a plug out of the fusebox while doing the matrix? Quote Share this post Link to post Share on other sites
mattkh 0 Posted May 20, 2007 anyone Hi Most likely an air lock. Which matrix did you go for ? How did you top up the coolant ? Quote Share this post Link to post Share on other sites
