cvw
water temp light
after draining all the water and coolant from my car yesterday to replace the matrix the temp warning light wont stop flashing , does this mean i have air in ithe system somewhere and how do i get rid of it.
The light will flash if the water level isn't high enough or its too hot.....in this case it seems as if there isn't enough water in the header or the sensors knackered!
anyone
Hi
Most likely an air lock.
Which matrix did you go for ?
How did you top up the coolant ?
