nocrap
More waterpump problems
I'm losing lots of water from my new water pump, it seems to be coming from around where the cam cover bolts on......I went to tighten the nut and found it was loose so i reached down to feel it and found that the T bolt had sheared!
1. Would the lack of this bolt cause the pump to leak???
2. I've just been looking on ETOS and there is no reference to the T bolt that is broken...any ideas??
3. In the list of part numbers it shows 2 water pumps.... Now the one for my car I believe is the £30 one but there's another one that's about £75......what's the difference? the part descriptions are the same......
Cheers all.
One is exchange, not the X at the end of the part number...
The T shaped bolt is a common part, N 900 534 01, found on the fische with the cambelt covers.
