jack 0 Posted June 10, 2007 Recently I have been having trouble with the water level in my car reducing. I have checked all hoses and cannot see any leaks. I have decided to replace them with Samco hoses. When looking at their web site they only offer rhd drive kits and US left hand drive, I have a LHD from Germany will the US kit fit? Quote Share this post Link to post Share on other sites
Jim 2 Posted June 10, 2007 Not the answer you're after but.. there are some truely "special" places that coolant can leak away so keep checking.. failing that, get your compression tested as your head gasket could well be on its way out :( Quote Share this post Link to post Share on other sites
VR6 0 Posted June 10, 2007 Could be worth replacing the coolant tank cap to the newer blue coloured ones, if you haven't already. Check round thermostat and temp senders as the housings can become brittle/cracked leading to leakage. Quote Share this post Link to post Share on other sites
