DUBST4R 0 Posted June 18, 2007 Hi guys, I recently had a mate of mine who plugged his VW diagnostic fault finding tool in, just to run a general check. The problem i have on the car is the abs light has recently come on. The above error codes came up which read as follows: 00561 - mixture adjustment control 00513 - Engine speed sensor GT28 - Idle rev too low/high or signal malnufunction. I spoke to another friend of mine who said generally the VW diagnostic readouts etc. are unreliable. Can anyone shed any light to the matter and if the read out is true, where these parts are located..? Are these common probs on VRs??? Quote Share this post Link to post Share on other sites
andy 0 Posted June 18, 2007 You need to interogate the braking system as well as the engine to find out the abs problem. The engine speed sensor code (iirc) you don't need to worry about. Its just because the engine is not running when tested. The other fault, mixture adaptation could be several things I think. I have that fault at the moment as well as a fault on the O2 sensor. I'm hoping a new O2 sensor will cure both... Quote Share this post Link to post Share on other sites
DUBST4R 0 Posted June 19, 2007 when u mean o2 sensor is this the co2 one; cat sensor? Quote Share this post Link to post Share on other sites
andy 0 Posted June 19, 2007 when u mean o2 sensor is this the co2 one; cat sensor? Yes, O2, lambda or cat sensor. Same thing afaik. Quote Share this post Link to post Share on other sites
DUBST4R 0 Posted June 21, 2007 when i get time will give it a go..and let u know if all is soted...cheers matey Quote Share this post Link to post Share on other sites
