dirtytorque
Flashing fault codes on an aftermarket ECU(G60)
I've had no luck with using the LED method to flash codes but i have just read an ABS fault with VAG-COM so at least I know the port does work. :|
What ECU is it???
Most aftermarket management does not have OBD and the G60 only had a limited function anyway - maybe plug a standard ECU in??
Jabba.
I have retrieved what I needed via vag-com anywy so i'm not going to the trouble of taking the ECU out.
Maybe the flashcode feature only works with the standard Digifant ECU as you say.!?!
Or at least not with a Jabba chip. :scratch:
