quicky1980 0 Posted June 20, 2007 I took the slave cylinder off for an engine change but now cant get it to fit back on. I accidentally pressed the clutch pedal down, so think its pushed the inner part of the cilnder out, can this be pushed back in? i tried to push but is very stiff, do i need to do something to push it back in? Quote Share this post Link to post Share on other sites
quicky1980 0 Posted June 21, 2007 anyone know? please? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 21, 2007 Shouldn't require that much force but maybe open the bleed nipple then re-bleed after you install... Quote Share this post Link to post Share on other sites
quicky1980 0 Posted June 21, 2007 ok will try, thanks Quote Share this post Link to post Share on other sites
quicky1980 0 Posted June 22, 2007 right sorted it, i took the slave cylinder off the car, didnt want to. but this allowed me to push really has down onto the piston, once it got passed a certain point it was really easy to push in. i even accidentally made brake fluid shoot 10ft. all bolted in now and just need to bleed the system thanks Supercharged Quote Share this post Link to post Share on other sites
