Clay 0 Posted June 22, 2007 I'm from South Africa, I had an imported G60 motor in my golf mkII, the G60 never came out here. But my charger broke a few weeks ago, the little timing/cam belt broke on the charger at high revs. I eventyually got my hands on another G60 supercharger and want to put it in my golf as soon as possible as it was my every day car. But before I do I want to replace that superchargers little toothed timing belt, I've heard some guys change that little belt on the G60s to a 12mm belt, nice! And I also want to put a fresh coat of the special grease on the inside of the charger. Could you guys please give me some info/specs/part numbers on the little toothed timing belt & that grease so that I can try match it up locally here in South Africa... Thanks a mil. Regards Clayton Quote Share this post Link to post Share on other sites
W3RKD 0 Posted June 22, 2007 .5" 120xl is what you need for the belt, And a non silicone PTFE greese will help. We can send both to you if needed. Quote Share this post Link to post Share on other sites
Clay 0 Posted June 22, 2007 Thanks a lot for the reply mate. I will what I can find locally here in South Africa... If i dont have any luck I'll contact you. Cheers. Quote Share this post Link to post Share on other sites
Clay 0 Posted June 28, 2007 Does anyone know if you get an equivalent or generic version on the Kluber Grease Nosol GBY 2 Quote Share this post Link to post Share on other sites
