CTWG60
as far as I remember it does not allow for more cooling. cooling is done by your cooling channels, oil and water, the contact things. If you had a hole there it would just be a problem to deal with and it would cost more. Air is terrible for heat transfer, keeps more heat in actually (basic thermo principle) . Not to mention that stupid little hole just bleeds your oil pressure when you dont tighten the one stupid bolt down... :D
you sure that is a lead for coolant???
I remember my oil pressure being 0 and tightening that plate is what brought it back up... yeah Im almost 100% on that plate being for oil... cause mine was ridiculously loose and I wansnt loosing coolant.
Im pretty sure its not coolant unless you know it is because there is coolant in it on your car...
either that or my car is just REALLY wierd.
how much boost would you like to run?
huh..... might explain my coolant build up on the side of my block... WTF why would they put that there?! yeah cooling makes sense, its only on PG engines?
