mattkh 0 Posted June 25, 2007 Hi I need some help. I cannot unscrew the 13mm nut on the weight as it turns. Am I turning it the right way? Do I need any special tool to hold it. What torque do I need ? Only want to push the grommet back into the eye at the end of the gear change cable. Thanks in advance. Quote Share this post Link to post Share on other sites
Yandards 0 Posted June 26, 2007 You will need to lock the stud that the weights sits on by holding another spanner underneath IIRC. Quote Share this post Link to post Share on other sites
