flyferrari 0 Posted June 29, 2007 Hi Guys, I have tried doing an advanced search on this but have got nowhere. If somebody would be kind enough to tell me how to do this on a VR6 engine or point me in the direction of instructions already written then I'd be most grateful. Regards Kevin Quote Share this post Link to post Share on other sites
drunkenmunkey 0 Posted June 29, 2007 Hi, suprised you haven't picked up anything on the search the ISV is a regular cause of stalling. Anyway, it's very simple you loosen the clip to the damper - the black plastic 'box' with 2 pipes on it, [it's been a while so it may be some other fixing] remove it, un plug the connection at the base of the ISV and then just slide the iSV out of it's rubber sleeve. To clean it get a plastic bag/jiffy bag [whatever it'll fit into], put it in, then submerge in contact cleaner from Maplin, soak for 5-10mins, shake it vigorously, remove. Then drown it in silicone lube & put it back. Et voila! rock solid idle...theoretically :) Good luck Quote Share this post Link to post Share on other sites
flyferrari 0 Posted June 30, 2007 Thanks for the reply. Whenyou say silicon lube do you mean standard silicon spray or something more specialized? Also are there any traps that are to be avoided? I'd hate to end up doing more damage than good.......particularly when the part costs a few hundred pounds!!!! Regrads Kevin Quote Share this post Link to post Share on other sites
staffs_til_i_die 0 Posted July 1, 2007 When you do it could you take some photo's? Mine's a 2.0 16v but I guess it should be similar. Quote Share this post Link to post Share on other sites
jonnyboyo 0 Posted July 1, 2007 As far as i know i think the isv's cost £120-ish, or not much more. So not a total disaster if you ruin it :) Quote Share this post Link to post Share on other sites
Skimask 0 Posted July 1, 2007 I wouldn't put silicone based lube anywhere near the intake system. I think silicon destroys the Lambda sensor. Quote Share this post Link to post Share on other sites
craigowl 0 Posted July 2, 2007 skimask makes a good point there. Quote Share this post Link to post Share on other sites
