ace666
kr inlet cam pros and cons
hello after reading about the possibility of changing the inlet cam on my 9a 2ltr 16v engine for the inlet cam from the kr engine i started wondering what are the benefits and what are the down sides to this mod .
for example is their an increase in bhp and if so around how much ?
any how many thanks
regards adam
All good, no bad, as long as the car is re-set up correctly and that is a big problem with Corrado's and Passat
bog standard 9A's do have a lovely flat torque curve though (for a valver), even if it does run out of steam at high revs.
