stuosb
cam change tappet question
I'd like to answer your question mate but it doesn't make any sense. If it helps, most of the engine variants use hydraulic tappets.
Yup - All C engines use Hydraulic lifters and these are fairly easy to change when the cams are out...
Dr Shrick advice new spings and tappets when fitting there cams but it is ok to fit just the cams...
