aftermathG60
idle issue
my 1990 G60 corrado has what sounds like a tapping in the motor, but was told by 2 mechanics that it is not in the motor but its the idle tensioner pulley rattling. any info?
I had the same problem on my G60/16v engine,it was def. the the tensioners the tension the ribbed G60 charger/alt belt so i stripped the tensioners and took off the small brass coloured washer located on the back of the tensioner and re-packed the bearings with fresh grease.This worked for a while but the tapping returned,my engine's tapping is very iiregular,sometimes it does'nt tap at all.God knows how much the tensioners cost from the stealer...
I've never known a cam belt tensioner to tap,they either work or sometimes sieze!,another short term remedy involves spraying the tensioners with WD-40 or simileur while the engine's running,the tapping noise instantly vanishes but not for long.
HTH.
